when I press one folder the songs aren't in alphabetical order ....... why Not ??????
I don't want to use the mouse everytime !!!
geposted Sat 02 Oct 04 @ 3:56 pm
The songs that were played last are shown at the top. I think there is a reg hack to change this.... Let me see what I can come up with.
geposted Sat 02 Oct 04 @ 9:43 pm
thanks Homeboy, I'd be instersted too, but by ascending bpm, not by alphabetical order.
a search on "sort" + "registry" in the General, Technical Support, Bug Report folder didn't yield any results.
I don't see a key that seems to let me parameter that under HKEY_LOCAL_MACHINE\SOFTWARE\VirtualDJ\ (except maybe AutoSort?), and I won't mess in VDJ's registry without being told to do so :)
This issue is one of the only things that forces me back from the XP10s to the mouse everyonce in a while.
Nicolas
Nicolas
geposted Sun 03 Oct 04 @ 6:13 am
hi
"This issue is one of the only things that forces me back from the XP10s to the mouse everyonce in a while"
same here, so it would be really great to have this
ivar
ivar
geposted Sun 03 Oct 04 @ 7:10 am
Your initial guess was right, just change the value of "AutoSort" in the registry to the column number you want to sort against.
geposted Sun 03 Oct 04 @ 3:10 pm
thanks dev
geposted Sun 03 Oct 04 @ 5:36 pm
yes, many thanks, worked like a charm.
For those who want the default sort to be bpm-based (4th column), the value to enter is "3" (the first column's value is 0).
Nicolas
Nicolas
geposted Sun 03 Oct 04 @ 6:09 pm
GREAT thanx a lot
geposted Sun 03 Oct 04 @ 6:37 pm
Hey i was wondeirng, see th columns with title artist bpm so on, why dont you press that? tell me what happens, are you worries over?
geposted Tue 26 Sep 06 @ 4:55 pm
What is the point of opening a 2 years old problem thread, which was obviously solved ??
geposted Tue 26 Sep 06 @ 5:03 pm
Hey duude then why did yu reply if its a two year old thread?
geposted Tue 26 Sep 06 @ 5:10 pm
The question is, why did you reply.
geposted Tue 26 Sep 06 @ 5:21 pm
