Forum: VirtualDJ Skins
Topic: Cue Variations
Dj-In-Norway
Could we have this skin in 1440x900?
Thanks!
geposted Thu 28 Jun 07 @ 8:51 pm
ronny582 wrote :
Dj-In-Norway
Thanks!
Ronny if you search the skins download area you will find three skins that are 1440x900 one is basic,one is loaded with many options and one has a buggy interface,your other option is to reset your screen resolution to fit 1200x800 then you can use some of the really nice skins but they will look like sh!t. Several vdj users have been begging for over a year for 1440x900 skins with no luck,oh don't let anyone try to pull the "Just try the resizer" line on you either.Good luck......P@40
