Forum: Old versions
Topic: Help mapping XP10 for hands-off-laptop use
The default configuration for the XP10 is pretty good. The only time I have to touch the computer is to load a track (which is to say, every few minutes).
How do I set up the mapper to make the pitch wheel scroll through the track list?
geposted Sat 02 Oct 04 @ 8:54 pm
Oops.. I think you probably knew I mean the jog wheel.
You could just use the arrow keys. They are already mapped.
the arrow keys will work, but unfortunately they won't "repeat", so if I want to go down 30 tracks, I have to press the down key 30 times.
Is there a way to make it so that it keeps going while pressed? or, as suggested, use the wheel (e.g. SHIFT2 + wheel = scroll).
thanks,
Nicolas
does somebody knows how by now ???
thanxxx
