Hi there,
as a regular user for a couple of years now I would suggest a sort of dynamics setting (compressor/limiter/expander) for VDJ.
I'm a resident DJ and I use my own gear plugged in in the bar's gear. The sound is sometimes like sh#t, because of alle the wannabees who try to be the most knowing DJ and technician in the world !
So independent of the sound i'd like to switch on the dynamics if the bar's equipment fails to do this
geposted Fri 06 Jul 07 @ 2:05 pm
you could use a good software VST compressor which is always set to on. Should do the trick ;)
geposted Fri 06 Jul 07 @ 7:04 pm
