Forum: Old versions
Topic: Problem also play from Songs (data base)
Hello,
excuse my bad English.
I have the following problem:
I put a MP3-DVD into the laptop and insert the songs of these DVD into the
data base. So far everything functions. Now I look for a song in the
data base and would like this song to play. however always the message
appears "please puts it to CD XX". These CD however still is in the
drive assembly.
Over job I cannot access also the CD and play the songs only over the
data base functioned that to play.
I have version 2.02, who can help me.
Thanks
DJChecker
geposted Tue 05 Oct 04 @ 10:06 am
when your database contains an item that has been moved or deleted it still shows the item!
when you try to load items like these, nothing happens.
i would adviceyou to play media from HD instead of dvd.
But your problem could be solved by clearing your database, and perform a new scan.
The data base will again delete. The inserted DVD is the first and
only medium which to the data base was taken up. Only the DVD did not
become scanned, no further CD, DVD or HD.
How do I clean the data base correctly (only CD remove)??
i'm not sure (i'm at work atm) i thought it was a simple right-click on the database-icon on top of the media-tree.
there you can select clear database and scan hd,cd etc.
Does not go in such a way it gives there only "Scan hp, Scan CD,
DELETE CD". Have CD was empty the data base deleted there. Afterwards
again "Scan CD" and it inserted contents again into the data base.
Calls does not know I the songs yet. Also analysis of the Songs is not
possible in the data base!
