Cel don't know if this was already answered but I cant get your text2d to work on Vista I get error d3dx9_32.dll was not found. You can kick me in the head if you have already answered this before but your help would be appreciated.
geposted Wed 11 Jul 07 @ 11:09 pm
Hi discobrian,
you just have to download the directx version from april 07 (or later if there's a newer version now).
Hopefully that should sort it. if it doesn't, somebody can kick me in the head too!
geposted Thu 12 Jul 07 @ 3:51 am
For Vista???
geposted Thu 12 Jul 07 @ 5:51 am
Well I will try it out and see. Thank u
discobrian
you may want to kick me in the head also, i'm running vista and having no problems are you remembering to activate text2d before you start to use it....
Tayla
Tayla
geposted Thu 12 Jul 07 @ 12:25 pm
It wont even let me activate it, thats when I am gettin this error. I am not giggin with this machine for a few more months so I am tryin to get it to run flawless on Vista.
geposted Thu 12 Jul 07 @ 7:51 pm
brian
don't know squat about computers but it looks like that code is saying theres something wrong with directx have you tried a fresh install of it or text2d, or am i just showing that i really don't no zilch about computers...lol
Tayla
Tayla
geposted Fri 13 Jul 07 @ 10:49 am
Hi discobrian again, it's working for me on vista as well!
http://www.microsoft.com/downloads/details.aspx?familyid=b406cf67-d926-463b-99e8-27199d6626b5&displaylang=en
If you havn't tried already, this is the june 2007 version. I recon it should work if you install it. I'm pretty sure there's a note on the download page for text2d that says something about directx, might be worth a check.
geposted Sat 14 Jul 07 @ 5:15 am
Ok somethin is screwy... direct x wont let me update on my vista and yes i am administrator... I am not giggin with this machine right now as I have a few months to get it to work on Vista. On my other drive I have Xp which has no issues runnin VDJ or any of the plugins. I will get this figured out damn it LOL
geposted Fri 27 Jul 07 @ 8:50 am
That did the trick!!!!! Thanks
geposted Mon 30 Jul 07 @ 10:35 am
Thanks... :)
geposted Thu 02 Aug 07 @ 4:11 pm
DJCel - please look at this post - it's a weird thing.
It has happen to me before - as you can tell by the post I know how to get around the problem. But every once in awhile I get the same message as reported in this post - http://www.virtualdj.com/forums/74404/General_Discussion/Error_using_Text_2D.html
Direct 3D is not initalized
geposted Fri 10 Aug 07 @ 4:42 am
hi well i have vista ultimite .
i dont get error messege but i cant get the 2d text to activate only the stripclub part can you guys help me with that part. i have a ati video card with two out put s .with its own power supply and its own 512 ddr memory. so it runs vdj beutifull.
geposted Sun 12 Aug 07 @ 3:18 am
Did you update DirectX? There is an update for VISTA here
geposted Mon 13 Aug 07 @ 1:25 am
It's not just a Vista Update - it is a 9.0c Update so good for XP and 2000 as well.
geposted Mon 13 Aug 07 @ 4:40 am
