Forum: VirtualDJ Plugins
Topic: text2d disappearing
taylaPRO InfinityMember since 2007
weird thing happened last night at the bar when trying to use text2d
after selecting text2d the box appears then when clicking activate the box disappears completely from the screen then it would for no apparent reason just reappear after a few minutes on screen, i would then type in some text then when clicking apply etc it would go blank only to reappear again a few moments later. i must point out the rest of vdj went smoothly as usual throughout the night.
i've being using this pluggin since its introduction & never had any problems at all so was this just a one off glich or is it a precursor for bigger problems to follow in vdj...
your help or thoughts would be appreciated...
Tayla
geposted Sun 15 Jul 07 @ 7:47 pm
djcelPRO InfinityModeratorMember since 2004
That's why this plugin is still in beta ;-)
The fact to let the user select the font makes the plugin "uncertain" even if i tried to protect all the code.
geposted Sun 15 Jul 07 @ 9:33 pm
ok, thanks, just that its been working great til' now just got a little paranoid
thanks again
Tayla
geposted Mon 16 Jul 07 @ 10:15 am
I too had this last night, for me the problem was that I had two copies of VDJ running at the same time. after closing VDJ1, the problem persisted until VDJ was restared, then all was fine!
geposted Mon 23 Jul 07 @ 1:31 pm
