hey ,
i have a little problem i bought atomix but there is only 3 effects !!! and when i want to download the others on this site, the "download" button is barred!!! is it normal.
(i checked , i was logged in )
others effects are only for pro version, or i can get it with v2.3. thanks to answer
geposted Mon 16 Jul 07 @ 6:11 am
you need to add your serial to your profile to get downloads.
geposted Mon 16 Jul 07 @ 10:22 am
T__T i dont have serial
can U give me serial ok ?
very very thx ^___^
very very thx ^___^
geposted Fri 17 Aug 07 @ 8:21 am
buy the software to get a serial.
geposted Fri 17 Aug 07 @ 10:51 am
plz i wont a serial
geposted Sat 01 Sep 07 @ 1:07 am
If you want a serial purchase the software. We all paid for it, and you should too....
geposted Sat 01 Sep 07 @ 1:35 am
