Forum: Old versions
Topic: changing grid marks to align with beat
Hi,
Just wondering how to change the grid/phase markers if the songs beats arnt aligned correctly, so they will stay like that everytime i open virtual?
geposted Mon 16 Jul 07 @ 2:26 pm
Go to the BPM settings (top side) and then manual tapping n change the anchor. Yes they will stay if it is properly closed the database (saved)
thats easier than what i thought, i thought you had to manually change the settings in a file somewhere.
Cheers.
actually you explained it abit to easily. lol
So, open the edit screen for the BPM, then it says
Anchor1
Anchor2
And
Anchor distance
*What i want to be able to do is tap the manual tap and have the grid markers be positioned where i tap,
Should i tap all the way through the song or will it automatically change all beats?
**Also on another quick note sosme of the songs dont display the Bpm in virtuals browser, any1 know of a way to add the beat in, may i have to change the actual file to store the BPM?
oopsy sori.. k here it is.
Still at werks , not infront my set now but i try to remember it:P
what i do is open the settings then at the edit grid..(first pick the song n let it play )manual tapping then listen n set beat anchor distance < > and there u could see when it hits the beats :)).. And when u done this u then can go to the edit bpm where u put the phase n aligned it properly(optional) . The next one is edit automix where u can edit the entry point n entry point for automix function.. hope that helps mates.:))
i couldnt understand much of that,
If you explain how to do it, you may need to explain it step by step in dummies terms because it seems alittle tricky.
I can,
manual tap and get the beats for the distance i tapped to line up correctly but after i finish tapping the phase/beat markers slowly go out.
I need to know how to get the whole song the same as the distance i tapped?
so after tapping for how ever long and im satisfied the beats are where i want them and i stop tapping, what do i do?
Hi there,, yes it will be automatic..remember to press ok.
I just read ur post again, and it best u do this, if only u want to aligned it (the bpm must be rite)., So u can skip the manual tapping part n move to the edit bpm part. Make sure that the bpm is correct, n just slide/move the phase n u will try to see the boxes (big n small) aligned correctly at the position(the first beat etc). And remember to press ok after done:)) It werks for me.
What i always do if my beat arent constantly or just a bit off when mixing, i will just nudge it n do it by hearing. Can't always trust computer:P
Maybe someone else will explain betta to u (more experience from me in this matter) or have some other idea..
let me koe if this help>>cheers
I never took the time to figure out the anchor set/manual tap stuff. It was confusing to me as well. I set up shortcuts on my keyboard to allow you to move the grid live. Then you can align right on the spot. Check out Norways blog for directions.
https://virtualdj.com/blog/dj-in-norway/
How do you set up these short cuts to move the grid?
