Hello,
I would like to developp a plugin for manual "automix":
-> move continuous or no-continuous the crossfader to the other channel by selecting a length (for example a slider).
MAXLENGTH=32s or more
by default = the default selection in settings if it exists
(as I don't like to have a fixed value)
-> possibility to modify the length during the "manual" automix
-> add buttons with different speed for no-continuous move
-> a special buttons to change instantly to the other channel
I have already integrated that to my personnal skin but it would be easier to concentrate all the functions for crossfader in the same place and independant of the skin => to free a part of the skin.
If you have finished programming before me, no probleme but share.
=> Macourteau or Kaleo: if you had a little time to do it, it would be great.
geposted Wed 06 Oct 04 @ 10:09 pm
An other vision of my idea:
-> set the crossfader in the middle
-> decreasing the volume level of current channel and increasing with synchro the volume level of the other channel in a defined time (=length) => slider
Maybe by using the same idea as the "FadeOut" effect by clax
=> first a "FadeIn"
=> then a "FadeInOut"
=> first a "FadeIn"
geposted Wed 06 Oct 04 @ 10:26 pm
I have very little free time these days -- barely enough to read the forum -- but other developers could give it a shot... This definitely sounds like a great idea, but also not a simple plugin.
macourteau
macourteau
geposted Wed 06 Oct 04 @ 11:00 pm
Clax:
It would be nice if I could get the source file (.cpp) of the "FadeOut" effet (the best would be without the option flanger) as now I'm spending my time recreating something which already exists.
or create your own .h if you don't want to share your work
Thanks
Thanks
geposted Thu 07 Oct 04 @ 1:17 am
Check your mail.
I sent you FadeOut source with a lot of comments.
Clax
Clax
geposted Thu 07 Oct 04 @ 5:24 am
Thanks
geposted Thu 07 Oct 04 @ 11:32 am
I think I will post your wish soon. Thr problem is to find time to.
geposted Thu 07 Oct 04 @ 5:26 pm
In VdjDsp2.h
In the structures TPluginInfos and TProvidedInterfaceInit:
what is "int size" ? Never seen in examples and I have no idea of what is refered to.
geposted Fri 08 Oct 04 @ 4:09 pm
I think that "CurrentDesk=0" means the corresponding desk in play. My definition is not clear :-(
However which integer when the other is in use : 1 ??
geposted Fri 08 Oct 04 @ 4:44 pm
What is "CurrentSlot"?
So to sum up: define "CurrentDesk" and "CurrentSlot" with the possible values and their meaning
Thanks
Thanks
geposted Fri 08 Oct 04 @ 5:27 pm
CurrentDesk returns on which deck the plugin is loaded (you do not need to know the values, it's used only for sending commands).
CurrentSlot returns on which slot on the current deck (1, 2 or 3) the plugin is placed. This (again) is used only for sending commands.
macourteau
macourteau
geposted Fri 08 Oct 04 @ 9:37 pm
djcel;
For Currentdesk and Currentslot, you can check the .cpp file that I sent to you; there's an example inside.
For "int size" I don't know; sorry.
Clax
Clax
geposted Fri 08 Oct 04 @ 9:44 pm
Hi, need help again
How can I know if desk=0 is linked to crossfader=0 or crossfader=4096 ?
geposted Tue 12 Oct 04 @ 6:29 pm
Does it work with :
int position_crossfader
GetParam(0,"Crossfader",position_crossfader)
And after i use "if (position_crossfader=0) " and "if (position_crossfader=4096)" to separate the two case.
But I can't reset th crossfader to the max at first
geposted Tue 12 Oct 04 @ 6:50 pm
-- With if ... else ... You have to write if (a==b) and not if (a=b).
-- Never tried with the crossfader but I'll start to create a plugin for this. I don't have much free time at all but I'll check ASAP.
Clax
Clax
geposted Tue 12 Oct 04 @ 7:23 pm
yes of course ==
Sorry for that
I didn't focuse on the right expression but only on the idea
Sorry for that
geposted Tue 12 Oct 04 @ 7:29 pm
geposted Tue 12 Oct 04 @ 7:37 pm
Well I have success in my plugin. The crossfader moves as I want
Just for info. It's the same algorythm as clax for FadeOut by only changing level by crossfader and by specifying some particular cases.
I had the idea to keep the flanger during the fade and i was supprised: it's great !!
Now I need FadeIn to finish my plugin and I have some other things to avoid (for example, forbidden the same plugin twice:one for each deck)
geposted Tue 12 Oct 04 @ 8:37 pm
I even think Fade is the big solution to my probleme
(only by changing level by crossfader)
;-) Clax
;-) Clax
geposted Tue 12 Oct 04 @ 9:01 pm
I would like to tell that the greatest interest of my plugin is that you can change the length of fade for crossfader during the mix without entering settings
Sniff, same problem as FadeOut when you are in a loop
geposted Tue 12 Oct 04 @ 9:25 pm
