Hello,
I downloaded a skin.exe
When I try to install this, I get the message that virtualdj not is installed.
I'm really sure that I have installed this.
What's wrong???
What's wrong???
geposted Fri 20 Jul 07 @ 9:17 am
Please add your serial to your profile as skins are for registered users only
http://www.virtualdj.com/fusers/modifuser.html
hope to see you with us soon.
geposted Fri 20 Jul 07 @ 11:14 am
I got virtualdj with my dj control mp3.
Is that enough?
Is that enough?
geposted Sat 21 Jul 07 @ 12:47 pm
add your serial from that please
geposted Sat 21 Jul 07 @ 4:50 pm
Hello,
When I have installed skins i have had no problem,
What i did was Install vdj then installed my dj controller
and loaded it up then i went on here looked at skins downloaded it.
gone into the file where my skin was doubled clicked it and it was in then gone into
the setting for skins on my vdj and applied.
but you are saying that when you go to load the skin it says vdj not installed.
now since you have the skins of this site as skyfxl says is defo could be the fact that
ur not registered so i would register your serial and then try again if failing that.
uninstall vdj and reinstall to start fresh register ur serial then do it all from there good luck!!!
geposted Sat 21 Jul 07 @ 5:30 pm
I have filled in the form, but I can't download any 1440 x 900 skin as "home user" .
Please does somebody have just 1 skin for me?
geposted Sun 22 Jul 07 @ 2:38 pm
try to make your own , or use the skin resizer to resize it to your screen or
if ud like the full featured vdj pro with all the skins , fx , plugins ect you can upgrade at a
discount because you own vdj home
geposted Sun 22 Jul 07 @ 5:41 pm
I want to upgrade immediatly to pro if I can download Multi Functions 1.5 Skin with a resulution of 1440 x 900
Please let me know
Please let me know
geposted Wed 01 Aug 07 @ 5:14 pm
For better replies , you should ask here:
http://www.virtualdj.com/forums/13/Skins.html
Thats where all the great skin makers hang out ;)
geposted Wed 01 Aug 07 @ 5:15 pm
