I ordered some timecoded vinyl yesterdy, does anyone know how long they take to arrive, Im in UK. Also does the demo version support them as im planning on buying the full version but want to test first.
geposted Thu 07 Oct 04 @ 11:59 am
I ordered mine on a Saturday, and got them on Thursday, I'm living in Holland.
Don't know if they work with the demo, but if you can activate timecoded vinyl in the settings, and even configure them, then I guess it would be possible...
geposted Thu 07 Oct 04 @ 12:38 pm
i was wondering if someone could tell how much the timecoded vinyls would be in us dollars, and i have used the trial in the past and would like to know if i can get another chance to use it with the vinyls when i order them, and with the trial it is possible to hook up a external mixer?? Vdj is almost where i wanted it to be, i been waiting for
geposted Thu 07 Oct 04 @ 5:08 pm
SO THE TIME CODED VINYL ARE THE BOMB HUH??
Anyone disagree.. just curious.. i was in Crobar this weekend and it seems the dj wasnt using records...feels like the real thing.. and you can scratch perfectly as if you had the 12inch.. is this right
geposted Thu 07 Oct 04 @ 6:28 pm
Hi,
- Yes the timecoded vinyl works with the last demo
- 14.95 euros = +or- 18$ in US currency (+ delivry)
- If you purchase a timecoded vinyl, we can allow few more days to the trial version, but you need to ask for it at: e-service
Coyote
Coyote
geposted Fri 08 Oct 04 @ 3:57 am
Time code best there is. If you are serious, you use time code.
geposted Fri 08 Oct 04 @ 8:36 am
Cant wait to get mine if it works good, Im buying vdj!!! Mind I might need a better USB soundcard or buy another as Ive got a Creative mp3+ which only has on line in. Mind it isnt much of a problem as I have always used standard vinyl in the past!
geposted Fri 08 Oct 04 @ 9:05 am
sounds good, from what i see, i need a sound card for each turntable? and the turntables go directly to the soundcard or can i use the output from the mixer?
geposted Fri 08 Oct 04 @ 3:23 pm
sorry i also wanted to ask how long do the vinyls last, do they suffer from cue burns, skips, dirt and normal wear. i though i read skips do no detect. this all true?
geposted Fri 08 Oct 04 @ 3:28 pm
An external mixer won't be usable with the demo though.
geposted Fri 08 Oct 04 @ 4:27 pm
