Topic: Info gone - Page: 1
All of a sudden all the info on the far left of the forms is gone. (IE: map, status etc)
any ideas of how to get them all back?
geposted Sun 22 Jul 07 @ 6:43 pm
I don't seem to have that problem... Maybe it was a small glitch =/
Could be, but what and how can I get it back??
There is no problem with the forum.
Just close your browser and open it again ;-)
Or use Firefox ;)
Already closed browser. Also I am using Firefox.
Still remains the same
remember you will never see icons on your own name
just others duno if thats what you mean
Alf
I updated and results the same.
Wanted to PM you about laptop but can not as that function is gone.
Sky:
Not my icons. I am talking about the usual info in the far left column. You know where it shows the stars and the map.
Isn't there a way to change it with the forum??
All else works, just not VDJ foum
Also I have even tried a restrore to earlier date. No Good either.
It's got to be a browser issue on your end. It works fine here.
Is it a perfect cut off - or are you able to see part of the column - and can you post a screen shot to your blog?
CSTOLL;
can't see any jpgs in blog. Was going to try and post here.
I tried to copy & paste, but that did not work. How can I post jpg here??
Probably need to use a free pic hosting and then use the IMG BB code:
 [ img] URL TO PICTURE [ /img]
Interesting - is this only with Firefox or does it happen in IE as well? Or any other browser for that matter?
Guess it worked. ANyway see what I am talking about?
Info on far left gone except for name.
That is strange..r u using firefox.. maybe try using explorer n c if this occurs too.
@Bogart
I sent you PM so you can reply my friend ;)
I have completely removed firefox and re installed it. Still not working. I tried to change the settings in browser and this remains the same. I think last week when this happened I hit something to change the way the forum shows, as it went haywire at that point.
I used SBC Yahoo and I can get on with everything showing correctly.
Is there any chance you reinstall OS? Might solve the problem.
You sure do love reinstalling the operating system hehe. Updating the java component most certainly would not do anything either. The forums only utilise javascript and that's for the navigation menu at the top, everything else is pretty much generated server side and sent as html.
The problem seems to be you are not getting images to load up, the reason for this? You probably blocked all images originating from virtualdj's domain. Firefox does not delete your profile when you uninstall so this explains why reinstalling the application did not change this. Click on Tools -> Options. Under the content tab click on Exceptions for automatic image loading and remove VirtualDJ from your block list.
91%
