* Mic Hi, mid, and Low eq.
* Balance
* Settings for hi, mid and low freqentions so thad you can adjust that so it's sounds better when you kill hi, mid, or low level (some kind of eq for the buttons that can be acces by rightclick or something.)
* Flashing buttons, what's easy to make in xml. for example.
<visual chan="1" onaction=''Play'' type="flashing" [settings="1s on 2s off"] or [on=''1'' off=''2'']>
<pos x="158" y="307" />
<size width="61" height="61" />
<on x="+0" y="+1024" />
<off x=''+0'' y=''+0'' />
<clipmask x="452" y="1573" />
<mask x="390" y="1573" />
</visual>
So it's easy to make a flashing element for each button and by the settings you can give the time how long it's most by on or off or normal and down or something.
* Balance
</visual>
geposted Mon 23 Jul 07 @ 1:09 pm
* Master level meter
* Mic level meter
* Fader start
* Mic level meter
* Fader start
geposted Mon 23 Jul 07 @ 1:14 pm
Patje_1 wrote :
* Fader start
There is already a plugin available for that
geposted Tue 24 Jul 07 @ 12:46 pm
