I am trying to find a bcd2000 midi xml for V3.4 the one on the external tools did not work.
geposted Tue 24 Jul 07 @ 2:37 am
why don't you upgrade to 4.2 it has option in settings to use the bcd2000 and you don't have to setup the midi mapping.
geposted Tue 24 Jul 07 @ 7:42 am
I use both V3 4 and V4 3 and I would like use the bcd2000 on V3 4 I know it can be done
http://www.youtube.com/watch?v=ZHb8vfoVlj4
geposted Tue 24 Jul 07 @ 9:59 am
if he did not do this in 4.2 then he did the Midi mapping himself.
In 4.2 I/you can do the same.
what he did was good, but was easy if you know what to do.
Upgrade and you will see.
NO Direspect to the DJ in the video!
His mix skillz bouncing the beat was way good, But....
YOU CAN DO IT too if you just take the time to practice.
geposted Tue 24 Jul 07 @ 11:15 am
If you use 3.4 just because you like the skin, you can use this one:
http://www.virtualdj.com/addons/skin.html?id=1517
with version 4.
with version 4.
geposted Tue 24 Jul 07 @ 11:24 am
