Hi, i allmost smashed my mac today as i tried to open vdj.
It worked yesterday, i need it for some work today and all it says is "internal database is corupted".
I´ve seen this on pc aswell but i dont remember how i fixed it.
After i press ok it says
"Invalid skin file (error line %i in the xml)"
Now i´ve moved all the files to the trash, and erased them, reinstalled and the same prob, done the same thing, tested with both the 12 and 13 vers (13 is the latest) and none of them are working, i´ve unzipped the skins but it did´nt help either.
Ive erased everything i´ve had when i searched for virtual dj. Restarted, installed restarted again, same problem...
Im sp frustrated, coz it feels like i´ve tested it all.
But it wont work no matter what i do.
How do i uninstall programs if it isnt just moving them to the trash as i´ve done.
Or even better how do i fix this problem
Thanks in advance
Best regards from Carl Johannes Drakenberg
Thanks in advance
geposted Wed 25 Jul 07 @ 6:37 pm
as i detailed in my email to you must not unzip the skins
and if they become unzipped in downloading you must zip them back up
or they wont work.
should after zipping the files back up it still wont run
delete this file /Users/yourname/Library/Preferences/com.atomixproductions.virtualdj.plist
then rerun vdj it will ask for your serial ,
and then it will be fixed
you will not loose your database
or they wont work.
geposted Wed 25 Jul 07 @ 7:15 pm
should you not know how to make them zips again
https://virtualdj.com/forums/70110/MAC_Version_Technical_Support/Important_Information_Regarding___Skins_For_Mac_.html
please consult this :)
geposted Wed 25 Jul 07 @ 7:16 pm
Same problem here on my Windows side yesterday. "Internal Database Corrupted". Once I get my Nou 4 going I need to sort this also.
geposted Wed 25 Jul 07 @ 8:15 pm
your issue seems different and somthing to do with bootcamp i have flaged it to the team
geposted Wed 25 Jul 07 @ 8:52 pm
k
geposted Wed 25 Jul 07 @ 9:34 pm
Thing is this happend before i even sent a pm to you (thank you VERY much for the skins) about the skins, this happend when i downloaded 2 skins WITHOUT touching them at all.
Ill wait with the skins you sent me.
geposted Wed 25 Jul 07 @ 11:10 pm
ok delete this
run vdj again and retype your serial hopefuly this should clear it up :)
geposted Wed 25 Jul 07 @ 11:28 pm
Didnt work :/
Same problem.
How do i erase vdj COMPLETLEY from my mac?
Thans in advance :D
Same problem.
Thans in advance :D
geposted Wed 25 Jul 07 @ 11:38 pm
lets try one last thing first
ok go to documents > virtual dj
and open up the file virtualdjdatabase(users).XML
in text edit.
and look near the end
ensure all the song tags are closed
they should look like this
<Song FileName="10 The Ultimate [Original Version].mp3" File Size="11993410" Tag Date="701160438">
<Display Author="KrisSy; Trixta" Title="The Ultimate [Original Version]" Tag Read="1" />
<Infos SongLength="16540416" />
<BPM Bpm="17640" Phase="2352" />
<FAME Is Scanned="1" Volume="8324" />
<Atomix Mix Type="3" Tempostat="1131312" Tempo End="15807792" Cut Start="1131616" CutEnd="16336704" Fade Start="1004544" FadeEnd="16356864" />
</Song>
Notice </song> at the end it is like that some songs near the end dont have this and have corrupted the sheet below them add this tag if it is missing
should this fail
download the free trial of Zap , the uninstaller for mac
and use it to remove virtual dj completely, unfortunately apple did not include an uninstaller in osx !
it should remove all the files for you so you may begin a fresh
in text edit.
</Song>
should this fail
geposted Wed 25 Jul 07 @ 11:45 pm
the database could not be opened, ill try the uninstall tomorrow
Thank you once again :D
geposted Wed 25 Jul 07 @ 11:53 pm
hope it works for you :)
geposted Thu 26 Jul 07 @ 12:23 am
Opened in Textedit, and found no songs (just the sample songs) Without the <song> bla bla bla </song> Like in html...
Here is what my previous file looks lite "copiying the whole text"
<VirtualDJ_Database Version="1" Date="18/11/2005">
<VirtualFolder AutoInit="1" />
<Song FileName="DJ Style & MC Loran - Ragga Pumpin [Promo Mix].mp3" FileSize="8782157" TagDate="511031848">
<Infos SongLength="16136064" Date="511031848" />
<BPM Bpm="19314" Phase="15218" BeatPhase="1" />
<FAME IsScanned="1" Volume="7692" />
<Automix MixType="3" TempoStart="111788" TempoEnd="14944940" CutStart="111872" CutEnd="15640160" FadeStart="103424" FadeEnd="15667200" />
</Song>
<Song FileName="DJ N'Erick feat. DJ Style - Satisfaction.mp3" FileSize="5572230" TagDate="511180255">
<Infos SongLength="15357312" Date="511180254" />
<BPM Bpm="18634" Phase="5077" />
<FAME IsScanned="1" Flag="7" Volume="6108" />
<Automix MixType="3" TempoStart="1346732" TempoEnd="13868780" CutStart="154176" CutEnd="14605024" FadeStart="26112" FadeEnd="14776320" />
</Song>
<Song FileName="DJ N'Erick feat. DJ Style - Satisfaction.mp3" FileSize="8358617" TagDate="511031301">
<Infos SongLength="15358464" Date="511031300" />
<FAME IsScanned="1" Flag="7" Volume="6227" />
<Automix MixType="3" TempoStart="1346732" TempoEnd="13868780" CutStart="154176" CutEnd="14605024" FadeStart="26112" FadeEnd="14776832" />
</Song>
<Song FileName="DJ N'Erick feat. DJ Style - Can't take it.mp3" FileSize="4034977" TagDate="511180257">
<Infos SongLength="11120256" Date="511180256" />
<BPM Bpm="28953" Phase="5259" />
<FAME IsScanned="1" Flag="7" Volume="4394" />
<Automix MixType="1" CutStart="1829344" CutEnd="10124576" FadeStart="497152" FadeEnd="10641408" />
</Song>
<Song FileName="DJ Seb MLMP - Born To Disco [extract].mp3" FileSize="1217831" TagDate="505032044">
<Infos SongLength="3352320" />
<BPM Bpm="19600" Phase="848" />
<FAME IsScanned="1" Volume="6814" />
<Automix MixType="3" TempoStart="471308" TempoEnd="2352868" CutStart="472576" CutEnd="3254624" FadeStart="162304" FadeEnd="3237376" />
</Song>
<Song FileName="DJ N'Erick feat. DJ Style - Welcome to my party.mp3" FileSize="4888449" TagDate="511180256">
<Infos SongLength="13472640" Date="511180256" />
<BPM Bpm="19313" Phase="4784" />
<FAME IsScanned="1" Volume="7913" />
<Automix MixType="3" TempoStart="2554100" TempoEnd="12133348" CutStart="2553760" CutEnd="12442464" FadeStart="16896" FadeEnd="13297152" />
</Song>
<Song FileName="DJ N'Erick feat. DJ Style - Elecktronik style.mp3" FileSize="7346116" TagDate="511031259">
<Infos SongLength="13497984" Date="511031259" />
<BPM Bpm="19746" Phase="4528" />
<FAME IsScanned="1" Volume="4896" />
<Automix MixType="3" TempoStart="83512" TempoEnd="12089080" CutStart="83424" CutEnd="12681568" FadeStart="16896" FadeEnd="12946944" />
</Song>
<Song FileName="DJ N'Erick feat. DJ Style - Open.mp3" FileSize="8330397" TagDate="511031300">
<Infos SongLength="15306624" Date="511031259" />
<BPM Bpm="18900" Phase="4952" />
<FAME IsScanned="1" Volume="4900" />
<Automix MixType="3" TempoStart="836552" TempoEnd="13234952" CutStart="836480" CutEnd="13972064" FadeStart="19456" FadeEnd="14686720" />
</Song>
<Song FileName="DJ N'Erick feat. DJ Style - Sing my song.mp3" FileSize="5581279" TagDate="511031302">
<Infos SongLength="10255104" Date="511031301" />
<BPM Bpm="22048" Phase="4564" />
<FAME IsScanned="1" Flag="7" Volume="4429" />
<Automix MixType="1" CutStart="709920" CutEnd="9001184" FadeStart="16896" FadeEnd="10041856" />
</Song>
<Song FileName="DJ N'Erick feat. DJ Style - Elecktronik style.mp3" FileSize="4897226" TagDate="511180222">
<Infos SongLength="13496832" Date="511180222" />
<FAME IsScanned="1" Volume="4804" />
</Song>
<Song FileName="DJ N'Erick feat. DJ Style - Open.mp3" FileSize="5553422" TagDate="511180222">
<Infos SongLength="15305472" Date="511180222" />
<BPM Bpm="18900" Phase="4956" />
<FAME IsScanned="1" Volume="4846" />
<Automix MixType="3" TempoStart="836556" TempoEnd="13234956" CutStart="836288" CutEnd="13972064" FadeStart="19968" FadeEnd="14686208" />
</Song>
<Song FileName="DJ N'Erick feat. DJ Style - Sing my song.mp3" FileSize="3720671" TagDate="511180255">
<Infos SongLength="10253952" Date="511180254" />
<FAME IsScanned="1" Flag="7" Volume="4341" />
</Song>
<Song FileName="Dmess & Franklin di felice feat. Style MC - Love all the hurt away (remix 2004) [extract].mp3" FileSize="1331617" TagDate="504131636">
<Infos SongLength="3669120" />
<BPM Bpm="20353" Phase="17979" />
<FAME IsScanned="1" Volume="7868" />
<Automix MixType="3" TempoStart="750567" TempoEnd="2704595" CutStart="344192" CutEnd="3640896" FadeStart="25600" FadeEnd="3652608" />
</Song>
<Song FileName="DJ Style & MC Loran - Ragga Pumpin [Promo Mix].mp3" FileSize="5854771" TagDate="511180257">
<Infos SongLength="16136064" Date="511180257" />
<FAME IsScanned="1" Volume="7564" />
</Song>
<Song FileName="DJ N'Erick feat. DJ Style - Can't take it.mp3" FileSize="6052736" TagDate="511031258">
<Infos SongLength="11121408" Date="511031257" />
<FAME IsScanned="1" Flag="7" Volume="4466" />
</Song>
<Song FileName="DJ N'Erick feat. DJ Style - Welcome to my party.mp3" FileSize="7332952" TagDate="511031302">
<Infos SongLength="13473792" Date="511031302" />
<BPM Bpm="19314" Phase="4286" />
<FAME IsScanned="1" Volume="7881" />
<Automix MixType="3" TempoStart="2553734" TempoEnd="12133478" CutStart="2553760" CutEnd="12442464" FadeStart="16896" FadeEnd="13298176" />
</Song>
</VirtualDJ_Database>
This is a direct copy and paste no modifications has been made.
Sorry for the trouble...
Best regards once again from me a.k.a Carl Johannes Drakenberg
</Song>
</Song>
</Song>
</Song>
</Song>
</Song>
</Song>
</Song>
</Song>
</Song>
</Song>
</Song>
</Song>
</Song>
</Song>
</Song>
That database contains nothing but the samples.
Just delete it, and start VDJ again, letting it build a new one.
Since you aren't loosing anything.
Unless you are opening the wrong XML file?
The PC version has two, where one is the one in use, called VirtualDJ Database(user name).xml
Dont have a mac (yet) so cant say for sure if its the same on the mac
geposted Thu 26 Jul 07 @ 12:30 am
Guess what :/
Same problem :(
ill try to unistall all files tomorrow by all i mean the app the installfiles the skins EVERYTING that has anything at all to do with vdj...
And then reisntall :D
Right now im about to sleep :D
See ya tomorrow :D
Same problem :(
See ya tomorrow :D
geposted Thu 26 Jul 07 @ 12:54 am
unfortunately im not convinced the mac database is rebuilt because when i have tried this the program wouldnt run at all it says invalid DB
geposted Thu 26 Jul 07 @ 1:00 am
Progress, progress..
I Zapped vdj (hahaha what an app, ill buy it because of the sounds :D) and the install files, loads of files where still there but i thought appzapper would do it...
so i let the remaining files be.
Reinstalled, started, serial, basic skin not ask me next time and then check for uppdates...
It waited a sec and then said database corupted as before, i got ready to slam my head into the table and pressed ok...
The computer looked at me for a second from the camera laying there on the table all depressed.... And then decided to be nice and started vdj without any problems :)
Now all i have to do is downloading the last uppdate again and see if it works...
Thx for telling my macbook whats right and whats wrong. My love for my mac is back again :D
Thank you very much for helping me out on this, you´re a good human being :D
Best regards from my mac and from me Carl Johannes Drakenberg
geposted Thu 26 Jul 07 @ 5:29 pm
glad to hear your back in business :)
geposted Thu 26 Jul 07 @ 5:47 pm
Im having this problem : invalid skin file (error line %i in the xml)
have tried deleting the file mentioned, but all it does is ask me to enter serial number then same problem.
please help
nick
p.s. just realised i have not registered my copy yet, ill get on that one in a mo.
Also i am using a mac os x 10.4, buthad same problem, so upgraded OS to snw leopard and still same issue
please help
nick
geposted Sat 26 Dec 09 @ 2:13 pm
hi there i get my new mac with leopard and i instal virtual vinyl on and give me a warning with version 5 and 6 of vv any one knows some thing about it ?? thanks
geposted Mon 28 Dec 09 @ 12:04 am
