I currently use the Hercules DJ Console MK2 PC and have it working with AutoMix Virtual DJ version 4.3.r12
I have updated my MK2 drivers to the most current version but I am receiving a very irritating issue to where my Hercules MK2 Master Tempo button automatically turns on when I am playing both tracks at the same time.
The beats would lock, the "Master Tempo" button would turn on and either the song would start skipping, jumping out of cue or a completely new song would automatically stop the current song and start playing.
How do I get rid of this? I don't want this to happen. Someone please help me.
geposted Fri 27 Jul 07 @ 11:02 am
It almost sounds as if Auto mix is turned on, but I suspect that the new drivers haven't installed properly, try uninstalling them and restarting your computer, try the new driver again, if the problem persists you could always revert back to the old drivers, Hercules are known for sucking when it comes to putting together decent drivers.
geposted Fri 27 Jul 07 @ 11:14 am
From what I know... Automix is turned off.
At the top of Virtual DJ, when both tracks are playing... the "Automix" button is dimmed, so i'm assuming it's off but the problem still persists.
On my other computer, I am having this same exact issue.
I will download the 2006 drivers from ftp://ftp.hercules.com/pub/webupdate/DJMk2/ and see if that helps.
If there are any other suggestions, please help me out.
geposted Fri 27 Jul 07 @ 11:22 am
I am running Windows Vista and this OS is not compatible with the 2006 drivers.
Thus, I am stuck with the 2007 drivers.
Could someone please help me out???
geposted Fri 27 Jul 07 @ 11:28 am
Hi could u pls register ur pro version:)..
Try latency to auto.& check shortcut..maybe u auto configure it.
geposted Fri 27 Jul 07 @ 12:19 pm
Spinna... the problem still persists.
geposted Fri 27 Jul 07 @ 1:19 pm
Completely uninstall the driver n try reinstalled again..
Hercules MK2 Windows Xp-Vista Driver ftp://ftp.hercules.com/pub/webupdate/DJMk2/2007_CMK2_2.exe
Hope this help n btw fuxor, if u currently own the v4.3, do modify ur status:)
geposted Fri 27 Jul 07 @ 1:46 pm
@fuxor
How do you use 4.3 when the demo is 4.2? Please remove that "funny" version and install 4.2 demo and try it then. Or modify your profile if you have bought VDJ.
geposted Fri 27 Jul 07 @ 2:44 pm
