Hi There
Hope someone can clarify this AMP situation for me.
Say for example you had this AMP...
http://www.electromarket.co.uk/pp/DJ_Amps_and_Speakers/DJ_PA_Karaoke_Amplifiers/Warrior_DA800_19_inch_Slave_800watt_Power_Amp.html
This AMP drives 4ohm @ 400w per channel or 8ohm @270w per channel.
As i understand it, by connecting 4 x 8ohm speakers, the impedance would effectively become 4 ohms.
So would you now be getting 200w going to each speaker?
Thanks
(Sorry, not too clued up on the whole amp situation)
Thanks
geposted Sun 29 Jul 07 @ 11:16 pm
Your math is absolutely correct :)
geposted Sun 29 Jul 07 @ 11:43 pm
