Topic: Feature question
Hi,
I'm looking to purchase some DJ software and am shppoing around for a suitable product. I want the software to be used in conjunction with vinyl playing and must have the following capabilities:
- ability to set tags anywhere within a track and enable/disable looping between two adjacent tags
- while looping, ability to disable the loop and continue playing the remainder of the track with a single keystroke
- while looping or in normal play mode, (a) ability to nudge the playpoint backwards or forwards by a fine amount (16th, 32nd of a beat, for example) or (b) by a large amount (1/2 a beat, 1 measure etc.) or (c) any arbitrary point based on a mouseclick
(You can probably tell what I'm trying to do - aurally synch up a PC track with a vinyl track etc.)
I would appreciate it if anyone could let me know if Virtual DJ can do this.
skajam66
geposted Sun 10 Oct 04 @ 2:14 am
why would you not adjust the vinyl track first?
