Forum: VirtualDJ Plugins
Topic: request for VideoCube
maybe an option for priority or ...
what i'm trying to do is...
playing videos
activate videocube
activate slideshow and still have the videocube effect going on
but when i activate slideshow the videocube effect disappears
(it will still be on the videos playing)
to have the videocube effect on the slideshow, too
i have to deactivate videocube and turn it on again
just a wish~~~
cheers,
matt
geposted Mon 30 Jul 07 @ 11:26 pm
This is the way it was intended. the last effect you apply, is applied to everything that was applied before. if you set "Use this pluging when no video present" option in video, under config, and set it as slideshow, it will replace the video for mp3's, and appear in the cube. When you then play a music video again, the videos will show instead.
The effects are "Layered" so you can arrange things the way you want, depending on the order you turn them on.
Exactly. You have to active the slideshow plugin first and then the videocube
If you use the slideshow when you're playing music only files, then it's probably best to do what was mentioned above so that it automatically appears.
If you just want it though as an effect while a video or visualisation is playing, you could make a keyboard shortcut that de-activates the video cube effect, then activates the slideshow and finally re-activates the video cube all with one key press.
You can do that in the "keyboard shortcuts" menu in config. Just ask if you need somebody to guide you through it.
thanx andy
will give it a try
matt
[Advert removed]
Please DO NOT post your advert on the forums again or your account will be locked.
Advertising is not permitted on the VirtualDJ forums.
Please also do not bump old topics - This topic is almost 4 years old.
[Old topic from 2007 locked]
