Forum: Old versions
Topic: About Updating To 2.04
Hi, I'm using VDJ 2.02 now, and want to update to v2.04. The question is, should I installl v2.03 update first before I continue to V2.04? or I can directly install the v2.04 update from my v2.03? Thx before.
geposted Sun 10 Oct 04 @ 2:56 pm
the update works with any version of VirtualDJ 2.
So just to be clear, does that mean that the latest update always includes the previous updates?
The current update contains the new .exe file (and maybe other modified files), which replaces the old one, and thus can be installed over any 2.x installation...
macourteau
I used to have samples and loops on my keyboard, but now the keys are not responding. I have gone to keyboard shortcuts to program the keys, but it is not working. What else can I do ?
Your shortcuts.txt has probably been replaced by the update.
-> You have to modify this file to your wishes
-> You have to create a copy of this file (and even you database.xml). In this case you can simply replace these files after an update or a crash.
Clax
I had a problem with 2.04, so I deleted it and installed 2.01 and installed immediately to 2.04 and it worked fine.
