I can't see any of the maps. Anyone else got this problem?
And more importantly. can it be fixed please
geposted Thu 02 Aug 07 @ 4:39 pm
Maps are there, check your browser settings.
geposted Thu 02 Aug 07 @ 4:41 pm
sorry alf pfd50 has the same problem i have had for a while now just thought it was my gear it keeps saying words to the effect can't zoom into this level try zooming out....
this is why for a while now have been saying instead of the map why not just have the users county/region and country embedded there instead would make instant recognition of where the person you are talking to comes from and would save leaving the page and then coming back to it...what do you think of that idea...
Tayla
Tayla
geposted Thu 02 Aug 07 @ 5:32 pm
My maps arent workin either.
geposted Thu 02 Aug 07 @ 5:39 pm
Can you guys post here what are you using, which browser and OS so webmaster can fix this?
I use XP with Firefox.
geposted Thu 02 Aug 07 @ 6:00 pm
dj alf
mines xp -
Tayla
mines xp -
Tayla
geposted Thu 02 Aug 07 @ 6:20 pm
seems like the google map api service has gone wrong
geposted Thu 02 Aug 07 @ 6:48 pm
Like i said b4 guys few weeks back in one of the tread i post.. the user map not werkin:(
geposted Thu 02 Aug 07 @ 10:52 pm
Vista
IE 7
Bog standard
Google Earth is working okay??????
IE 7
Bog standard
geposted Thu 02 Aug 07 @ 11:39 pm
I use XP with IE7....
geposted Thu 02 Aug 07 @ 11:43 pm
user map - FUBAR... still.
geposted Fri 03 Aug 07 @ 10:52 am
At home on my Vista laptop with IE7, it doesn't work.
At work on my WinXP desktop with IE6 it works.
geposted Fri 03 Aug 07 @ 11:39 am
Does not work on XP with IE7 at my work.
Looks like an IE7 issue
geposted Fri 03 Aug 07 @ 12:01 pm
Now ,... the user map werks:)
geposted Sun 19 Aug 07 @ 8:32 pm
Mine still doesn't work...:(
geposted Sun 19 Aug 07 @ 8:33 pm
its working here guys
geposted Sun 19 Aug 07 @ 8:37 pm
