No matter what I have the fade length set to in the settings section, when you activate the automix button, the auto mix goes from deck to deck in about 1 second! Any suggestions as to how to set or re-set the fade length
geposted Sun 10 Oct 04 @ 11:54 pm
You could try loading the songs on the decks, and then editing their automix properties... I don't use automix, so I don't know if this will help, but here's how you can try it out:
1) Load both songs on the decks, and then for each one of them, right-click them in the browser, and choose "Edit Bpm".
2) Then, go to the third tab ("Edit AutoMix"), and you can try changing the settings for each song... Hopefully this will help the automix.
macourteau
macourteau
geposted Mon 11 Oct 04 @ 2:44 am
sorry, this does not help.
geposted Mon 11 Oct 04 @ 12:40 pm
I think 'll try to create a plugin for an automix a a choosed moment in the song.
But I really have no time these days.
geposted Mon 11 Oct 04 @ 6:13 pm
I DJ'ed a party last night with version 2.04 and used the automix feature from the playlist all throughout dinner without any problems.
You need to have the "Force Fade" option int the FAME Settings enabled though.
geposted Mon 11 Oct 04 @ 7:38 pm
Hi I'm using trial version of Virtual DJ for now, will purchase soon, only thing is I cant find how to scan for all my songs on computer, when I search for song won't find it.. I got AtomixMP3 and it does scan for all my songs..
Can someone help me..
Thank You Very Much!!!
geposted Tue 12 Oct 04 @ 3:15 am
zeus101: did you select "Database" in the left window of the browser before searching (and after scanning your harddrive, of course)?
geposted Tue 12 Oct 04 @ 3:21 am
No matter how much I read the threads about this subject I cant get this to work.. It just gets more confusing..
What do I do and how? In real simple terms.
geposted Wed 27 Oct 04 @ 2:13 pm
To zeus101 & DeGothia:
Many users find a whole new assortment of problems with improperly cracked or illegal versions of VDJ. I recommend you uninstall your bad version, and try the actual legal trial version before you report problems that no one else seems to have.
geposted Wed 27 Oct 04 @ 2:21 pm
