Hi,
I have some Ambient video files in vob format or mpeg format and I want to convert them to svp file so that I can play them in vdjpro.
Does anyone know how to do this ?
Many thanks!!
Many thanks!!
geposted Thu 02 Aug 07 @ 5:48 pm
Sonique Visuals are coded plugins like MilkDrop visuals - they are not videos. You can not convert videos to SVPs.
geposted Thu 02 Aug 07 @ 5:50 pm
Thanks
Is there any way that I can play the ambient video's that I have got in the format I have in vdjpro?
geposted Thu 02 Aug 07 @ 6:19 pm
Not as a back drop while mixing between the two decks in a single instance mode. VDJ can however be run in a Multi-instance mode which would provide you 4 decks and then you might be able to make it possible.
- however you will want to spend some time researching the forums for MultiInstance capabilities and post questions about it.
geposted Thu 02 Aug 07 @ 6:38 pm
cstoll
would it be possible to use the g-force effects, look much better than sonique but don't know if they are compatible for vdj...
Tayla
Tayla
geposted Thu 02 Aug 07 @ 7:10 pm
Thanks very much.
One other question, is there any way I can make the decks to automix without the song be in a playlist.
For instance if I open a file in the browser is it possible for player to work down the songs in the folder and automix?
Thanks
Thanks
geposted Thu 02 Aug 07 @ 7:14 pm
tayla wrote :
cstoll
Tayla
Tayla
Not familiar with those.
But remember for the beat-aware or music-aware type effects G-force, MilkDrop, etc. someone would have to develop/program a plug-in to make it integrate / interface with VDJ.
So unless someone does this - the Sonique plug-ins are your Ambients to use.
My recommendation for the PO Ambients - BUILD long playing DVDs and run them seperate through a DVD player -- don't put the load on VDJ to play a pre-programmed video that isn't even beat/music aware. Simple push button switcher between a DVD Player out put and the computer output.
geposted Thu 02 Aug 07 @ 7:17 pm
thanks for the quick reply cstoll...
Tayla
Tayla
geposted Thu 02 Aug 07 @ 7:22 pm
cstoll you still about urgent help please
Tayla
Tayla
geposted Thu 02 Aug 07 @ 7:24 pm
Sorry - wasn't still there -post your issue in a new thread unless it is on this same topic
geposted Fri 03 Aug 07 @ 3:30 am
