I own both VDJ and Atomix. In my case it seems like Atomix mixes my songs more smoothly than VDJ. It seems like the mixes are more seamless. There is fewer beat mismatches and hesitation. What settings would I use for VDJ to accomplish this?
geposted Fri 03 Aug 07 @ 4:30 pm
VDJ sounds and reacts light years ahead of the old Atomix software. Now the settings are up to your machine. You have to tweak the configs to best suit your computer.
First-what version are you using of VDJ?
Second-What are your computer specs?
Also check here
http://www.virtualdj.com/forums/64699/PC_Version_Technical_Support/SELECTED_SOFTWARE_GUIDES.html
MS
Also check here
MS
geposted Sat 04 Aug 07 @ 4:23 am
I am not able to load all my mp3 files into VDJ, any ideas.
geposted Sat 04 Aug 07 @ 4:30 pm
