Hi,
Is it possilbe to have more than the default 12 sampler slots. I found a utube link video example of someone using 24 sampler slots. Here it is:-
http://www.acidplanet.com/components/embedfile.asp?asset=794286&T=1020
I'm sure I found this option of using 24 slots some time ago, but can't work out how! I was thinking, is available to certain skins?
Thanks
Thanks
geposted Sat 04 Aug 07 @ 8:58 pm
Hi there,
He's using a "multi-instance" skin.
If you have a look round the skins section you should be able to find a few. Once you've got it open, you just select the sampler on each instance and you'll be up and running!
geposted Sun 05 Aug 07 @ 3:25 am
Ah thankx for the info.
After searching for skins, the only multi-instance skin download I can find is Author: djcel, Created for VirtualDJ version 3.01
Unfortunately this doesn't work on my version i.e. VDJ 4.3 on Windows Vista? any other skins you know of?
Cheers
Cheers
geposted Sun 05 Aug 07 @ 9:16 pm
How abt V mix 5.2? By dj format. Make for version 4xxx and Its a multi instance indicated on the skin:) This skin is great , i currently use it but never do that multi skin thingy tho:) Maybe u could give it a try, no harm:)
http://www.virtualdj.com/addons/skin.html?id=3152
geposted Sun 05 Aug 07 @ 10:13 pm
V mix 5.2? By dj format is a good skin but doesn't do the trick. Has anyone found a skin that can enable 24 slots of samples simultaneously as in the video in my first post?
geposted Sun 12 Aug 07 @ 1:38 am
this is the skin for you :)
http://www.virtualdj.com/addons/skin.html?id=967
muliinstance , should load up 4 players instantly but if not
go into options enabled multi instance and restart vdj
geposted Sun 12 Aug 07 @ 1:50 am
Sky... i think he had already try that skin..as he stated ;)
Cheers
Cheers
geposted Sun 12 Aug 07 @ 6:47 am
what error message do u get if any?
geposted Sun 12 Aug 07 @ 10:45 am
