Dear Helpdesk,
I own Pioneer Equipment like DVJ-1000, CDJ-1000 MKIII and mixer DJM-1000 can i easily connect this to Numark Cue or Virtual DJ Pro on a computer and give that no technical problems?? or can i only use Numark equipment?
Kind Regards,
Peter (Netherlands)
Moderated by Lady Cameron
Sorry 24se7en no email address is allowed from a demo user
Kind Regards,
Peter (Netherlands)
geposted Sun 05 Aug 07 @ 12:51 pm
You can connect your CDJ1000 CD-players with the free timecode CD and control VDJ with your Pioneer players.... This way you will control the mp3 playback in VDJ just as if the mp3's where on the CDJs
The DJM800 (I guess you mean that mixer?) has midi, and can also control Virtual DJ, such as effect, cues or what else you want to map to the midi functions
So answer is yes, you dont need Numark gear
geposted Sun 05 Aug 07 @ 12:59 pm
Dear DJ in Norway,
many thanks... can i also control the videoclips that are on my Harddisk and playlists in Cue by Pioneer VDJ?
geposted Sun 05 Aug 07 @ 3:24 pm
Dear DJ in Norway,
are you also the owner/producer of the skin DJ-1000 for Virtual DJ..?
I want to contact the people/owners of Virtual DJ, i need a program like Cue or Virtual DJ with some function buttons with connections for types/genres/styles of music. My company will rent Viedeoclips and MP3 data to Bars and Hotels etc.
Kind Regards,
Peter
Kind Regards,
Peter
geposted Sun 05 Aug 07 @ 3:52 pm
24se7en wrote :
Dear DJ in Norway,
Everything you do with audio you can do with video (except recording) in VDJ, so the answer is yes.
Check this page:
http://www.virtualdj.com/support/manual/
or
http://www.virtualdj.com/forums/55342/General_Discussion/Video_Demonstrations_of_Virtual_DJ.html
geposted Sun 05 Aug 07 @ 4:47 pm
Are you planning to put up VDJ as a mix system at hotels?
VDJ can sort by genres, and you can make playlists...
and even automix from that..
geposted Sun 05 Aug 07 @ 11:23 pm
Yes! we're planning to make a system for DJ/VJ'sin Bars/Hotels etc within a possibilty with select genre buttons so that everybody can use this system and select as example a genre playlist. If your company can produced this kind of system or we can buy/use your source codes and produce by our own.
Kind Regards,
Peter
Kind Regards,
Peter
geposted Mon 06 Aug 07 @ 7:47 pm
VDJ already has a system like that, called DJ-BOX.
Will ask CEO if its still something they are providing.
geposted Mon 06 Aug 07 @ 7:52 pm
