I love this skin, works real good with I do. Only problem I'm having is....once I've used the program for about 5 minutes, I can access other programs on the task bar. When I try to access them, my projector screen flashes and the program won't come up in front of the skin. The mouse pointer jumps from the task bar to the middle of VDJ. Now if I minimize VDJ, what ever program I accessed will be on the screen. Then I can't close it, minimize it or bring VDJ back up. I use 2 other programs when I do my gig. I use wordpad to keep track of the singer rotation if I have singers and I use kbooks, which contains all my songs, video (mostly what I have on DVD's) and karaoke. I need these to do my gigs. Any idea what might be causing this?? I love the skin and would like to be able to use it.
Thanks
Thanks
geposted Tue 07 Aug 07 @ 4:08 am
Not sure exactly what is going on there. Can you post system specs and maybe a screenshot or 2 to explain the problem further.
Hope to get this sorted for you
DJ Mykel
DJ Mykel
geposted Tue 07 Aug 07 @ 6:28 am
Never mind. Must of been a glitch somewhere the first time I used the skin. For some reason, the VirtualDJ(2), the MP3 bar was actually at the top of the screen, over VirtualDJ(1). I went back to the orginal screen to use the program. Today reloaded the V Mix to make a screenshot and the MP3 Bar was at the bottom and now I don't have any problems with the task bar. Thanks for your help.
geposted Tue 07 Aug 07 @ 3:51 pm
good to see you got it sorted . V Mix 6.0 Coming Soon
geposted Tue 07 Aug 07 @ 9:38 pm
I want skin dj 5.2? why I download not?
geposted Fri 10 Aug 07 @ 11:34 am
you need to buy virtual dj :)
geposted Fri 10 Aug 07 @ 11:54 am
DJ FORMAT,
Just wanted to tell you V Mix 5.2 is AWESOME. I used it all week for the first time and it's the best! THIS should be the Default Skin for Virtual DJ 4.3 Full Video! And so far, I've found it to more stable than the default full video skin, if I can say that? I noticed a little thing like, when you 'highlight' a song, say in the play list, it does it with the first click. Most of the time, with the default skin, you had to click it several times to get it to highlight. I have a lot more control of everything and customizing the screen for what you want is terrific.
And I'll let you know after I've used it for a few weeks but, I didn't have a single freeze or crash. With the other skin, I had at least one a week. My son, who is a Junior at Wright State..majoring in Computer Engineering, told me it is possible that a skin could trigger a crash. Don't know if it's true, but I will keep you informed. Matt, thanks again for a great skin! Made my whole week!
geposted Sat 11 Aug 07 @ 10:15 pm
Thank You
geposted Sun 12 Aug 07 @ 1:53 am
Oops, spoke too soon, crashed on me last night. Still love the skin though.
geposted Sun 12 Aug 07 @ 2:59 pm
I upgraded to VDJ 5.0 and for some reason I lost the little microphone icons you used to depict karaoke songs. Is there a way to get them back? Also, all the icons went back to the original icons of the default skin. Like the ones for the V Mix 5.2 better. Would like to get them back. Is there an upgrade on the skin?
geposted Thu 23 Aug 07 @ 8:27 pm
yes
Browser Update Black Blue Red For VDJ V5.0
V-Mix 5.3 Single Instance 1280 x 768
V - Mix 5.3 Single Instance 1280 x 800
V - Mix 5.3 Single Instance 1280 x 960
geposted Thu 23 Aug 07 @ 9:13 pm
geposted Thu 23 Aug 07 @ 9:14 pm
