Is anyone coming up with a mapper for NTC?.
I would like to change sample control to video effects.
Thanks
Thanks
geposted Wed 08 Aug 07 @ 5:33 pm
Thanks
Thanks
geposted Fri 10 Aug 07 @ 12:28 am
I wish I had a NTC in order to make a working mapper...
geposted Fri 10 Aug 07 @ 12:31 pm
i know how to make a skin, but this ...
hopefully somebody is working on it
in the meantime can somebody explain me/us how to make one, please
or post a link
maybe i will give it a try
cheers,
matt
or post a link
cheers,
matt
geposted Fri 24 Aug 07 @ 5:41 am
You can add in vdjDevice.h after "#define PLUGINDEVICE_ICDX "
#define PLUGINDEVICE_DMC2 8
#define PLUGINDEVICE_KC0 9
geposted Fri 24 Aug 07 @ 11:55 pm
Did you ever get that figured out?
I would like to change the cross fader to be video only, but still use it as a USB device.
geposted Fri 21 Sep 07 @ 2:07 am
In crossfader audio option select disable and in video option select link crosfaders and your crossfader will be only for video, no any mapper is necessary ;)
geposted Fri 21 Sep 07 @ 8:37 am
FROM the VDJ STAFF:
To make the cross fader act as a video device
OnSlider(int chan,int slider,int absvalue,int relvalue)
char cmd[32];
switch(slider)
case KC0_SLID_CROSSFADER:
wsprintf(cmd,"video_crossfade %d",absvalue);
SendCommand(chan,cmd);
break;
It should work like that.
Best regards
char cmd[32];
switch(slider)
break;
Best regards
geposted Thu 04 Oct 07 @ 8:48 pm
My question is does the above routine live in the KC0Mapper.h class?
geposted Thu 04 Oct 07 @ 8:51 pm
Here is what I have (so far), but I am getting an error. Any help?
<mapper.cpp>
#include "stdafx.h"
#include "mapper.h"
#include "vdjDevice.h"
#include "KC0Mapper.h"
char cmd[32];
switch(slider)
break;
<error>
.\mapper.cpp(9) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
.\mapper.cpp(15) : error C3861: 'wsprintf': identifier not found
.\mapper.cpp(16) : error C3861: 'SendCommand': identifier not found
.\mapper.cpp(19) : warning C4508: 'OnSlider' : function should return a value; 'void' return type assumed
<mapper.cpp>
#include "stdafx.h"
#include "mapper.h"
char cmd[32];
switch(slider)
break;
<error>
geposted Thu 04 Oct 07 @ 9:23 pm
