whilst surfing i found this amazing tool ,
it scans your system and finds all of the settings , and hardware problems however slight that are slowing your machine down,
it can show you how your system compares to others , what you could upgrade based on the motherboard or parts you have to make it run faster
it can aslo detect any missing or out of date drivers and help you download any patches needed.
it can aslo help optimise the performance of video and mp3 usage and compression
Grab your free copy here
http://www.cpuid.com/pcwizard.php
"PC WIZARD 2007 is a powerful utility designed especially for detection of hardware, but also some more analysis. It's able to identify a large scale of system components and supports the latest technologies and standards. This tool is periodically updated (usually once per month) in order to provide most accurate results.
PC WIZARD 2007 is also an utility designed to analyze and benchmark your computer system. It can analyze and benchmark many kinds of hardware, such as CPU performance, Cache performance, RAM performance, Hard Disk performance, CD/DVD-ROM performance, Removable/FLASH Media performance, Video performance, MP3 compression performance.
Hardware Information
Mainboard / Bios (Connectors, ID String, MP Support ...)
Chipset (FSB Frequency, Norhtbridge, Hub, Direct Media Interface, XMB, NSI, ...)
Main Memory (FPM, EDO, SDRAM, DDR SDRAM, DDR-2 SDRAM, RDRAM, FB_DIMM, Timings ...)
Cache Memory (L1, L2, L3, Size, Frequency ...)
Processors (Type, Speed, Multiplier coeff., Features, Model Number, Vanderpool Technology ...)
Coprocessor
APM & ACPI
Busses : ISA, PCI, AGP (2x, 4x,8x), SMBus/ i2c, CardBus, Firewire, Hyper-Transport ... )
DMI / SMBIOS
Mainboard Sensors, Processor, Hard Disk & Battery (Voltage, Temperature, Fans)
Video (Monitor, Card, Bios, Capabilities, Memory, Integrated Memory, Frequencies ...)
OpenGL & 3Dfx
DirectX (DirectDraw, Direct3D, DirectSound (3D), DirectMusic, DirectPlay, DirectInput, DirectX Media)
Keyboard, Mouse & Joystick
Drives (Hard Disk, Removable, CD-ROM, CDRW, DVD ...)
SCSI (Card, Controller, Adapter, Devices ...)
ATA/ATAPI & S-ATA (Devices, Type, Capabilities, S.M.A.R.T. Features, RAID)
Ports (Serial, Parallel, USB, IEEE-1394)
IDE & SCSI Devices
Twain & WIA Devices
PCMCIA (PC Card) Devices
Bluetooth Devices
Sound Card (wave, midi, aux, mix, AC'97 codec, High Definition Audio)
Printers (Local & Network)
Modem (Features, Speed ...)
Network (Server, Connexion, Firewall ...)
Security (Scan Ports ...)
PocketPC & SmartPhone Devices
System Information
MCI Devices (mpeg, avi, seq, vcr, video-disc, wave) & ACM
SAPI
Passwords (Outlook, Internet Explorer, MSN Messenger, Dialup ...)
MSN Password Recovery
DOS Memory (base, HMA, UMB, XMS, EMS, DPMI, VCPI)
Windows Memory
Windows (Version, Product Key, Environment, Desktop, XP Themes ...)
Windows UpTime (Boot, Shutdown, BlueScreen, System Restore Points ...)
TrueType & OpenType Fonts
WinSock (Internet), Telephony et Remote Access
OLE (Objects, Servers ...)
Microsoft® Applications
Activity (Process, Tasks, Threads)
Modules (DLL, DRV, 32 & 16-bits) & NT Services
Internet Navigator (Microsoft Internet Explorer, Netscape, Mozilla, FireFox)
ODBC
CMOS/RTC
Resources (IRQ, DMA, E/S, Memory)
System files (.ini, .log, .bat, .nt, .dos ...)
System Benchmarks
Processor (Dhrystone (MIPS), Whetstone (MFLOPS), Mandelbrot fractal ...)
L1, L2, L3 Cache, RAM (Bandwidth, Latency ...)
Main Memory (Bandwidth, Latency ...)
Hard Drives
CD/DVD Rom
DirectX 3D
Video
Removable/Flash Support
MP3 Compression
VISTA Experience Index
MEMORY and CACHE: These benchmarks measure the maximum achiveable memory bandwidth. The code behind these benchmarks method is written in Assembly (x86, SSE, SSE2, SSE3). Memory benchmarks utilize only one processor core and one thread.
PROCESSOR : These benchmarks measure performance in terms of Integer Millions of Instructions Per Second (Integer MIPS) and Millions of Floating Point Operations Per Second (MFLOPS). The code behind these benchmarks method is written in Assembly (x86, x87, MMX, SSE, SSE2, SSE3, 3DNOW!). Processor benchmarks are HyperThreading, multi-processor (SMP) and multi-core (CMP) aware.
Tools
Can save, print, e-mail a report
Can save a TXT, RTF, HTML, PDF or CSV report
Can export any graphics as BMP file
Can export text and graphic with the clipboard
Web update Wizard
Communicate with Motherboard Monitor
Dump (Hardware registers, System BIOS, video BIOS ...) "
Coprocessor
APM & ACPI
DMI / SMBIOS
OpenGL & 3Dfx
IDE & SCSI Devices
Twain & WIA Devices
Bluetooth Devices
System Information
SAPI
Windows Memory
ODBC
CMOS/RTC
System Benchmarks
Hard Drives
CD/DVD Rom
DirectX 3D
Video
MP3 Compression
Tools
Web update Wizard
geposted Fri 10 Aug 07 @ 2:52 am
