Do you have a 100% signal? Did you do the -13dB fix for your timecodes?
geposted Tue 21 Aug 07 @ 9:34 pm
I have 0% signal ... and im not aware of the -13db fix for timecodes .. were to get it or how to apply it.
If someone could point me in the right troubleshooting direction ... the only directions I could find were out dated and half in another language.
https://virtualdj.com/support/VirtualDJ%203%20-%20Advanced%20ASIO%20configuration.pdf ... not a ton of help that is.
And yes .. I have searched and read all day looking for help on this ..
geposted Tue 21 Aug 07 @ 10:43 pm
Ah, this is probably why you're having trouble. The higher quality cd decks don't like the VirtualDJ timecode if it's not been adjusted. There is a download option on the site for the fixed signal but the link doesn't work.
Edit: it seems that the tool I used to do the audio tweaking has gone down, so my tool is effectively useless heh. I'll get a link for you so you can do the tweak manually.
geposted Tue 21 Aug 07 @ 10:45 pm
http://rapidshare.com/files/50417103/pioneer_fix.zip
Download that and run the convert batch file. It will make a fixed timecode signal.
geposted Tue 21 Aug 07 @ 11:01 pm
Andrew, I just downloaded it, am I to assume that the timecode that is in there, has already been lowered?
geposted Wed 22 Aug 07 @ 1:55 am
No, that's the original timecode file. If you run the file which says convert and then wait for the dialog to close, it will create the lowered.
geposted Wed 22 Aug 07 @ 1:57 am
Ok .... ive got two versions of VDJ running.
4.3 .. .same problems as has been mentioned in this thread .... nothing has changed...even with the new cd.
5.0 ... I still get 0% quality ... but it plays longer then 12 min .. not sure the exact time yet but I will let everyone no.....
also I burnt 6 tracks onto the cd .. .but every time it loads a new track it pauses the live music for 3 seconds unless I turn time code off while it does this.
I'm still hoping someone can help me get 4.3 working ... I'm comfortable with that version and do not want to upgrade yet.
geposted Wed 22 Aug 07 @ 3:37 am
It's possible that the besweet utility doesn't do a good enough job for reducing the volume for the timecode. You can download a free program called Audacity and use the amplify tool in that software to manually set the gain to -13db. Save that as a new wave file and try recording that.
geposted Wed 22 Aug 07 @ 4:07 am
no luck yet
geposted Wed 22 Aug 07 @ 4:59 am
*bump*
geposted Wed 22 Aug 07 @ 5:34 pm
https://virtualdj.com/products/timecode/cd.html
Use the PRO GRADE timecode
And press auto config in VDJ timecode setup
Works straight out of the box with me, both cdj800 and cdj1000
geposted Wed 22 Aug 07 @ 6:18 pm
@dj-in-norway
I can not download that file ... it tells me to use the user name & password for "team only"
could you PM me the proper credentials.
geposted Wed 22 Aug 07 @ 6:47 pm
I'm getting that as well, asking for a user name and password. Also Norway I read in another post that other time code signals will work with version 5, I've got Torq and Serato Time Code CD's. What do I have to do to make these work. Thanks
geposted Wed 22 Aug 07 @ 6:49 pm
Serato timecode CD will be supported real soon by plugin a user made.
Torq might too, if any user make one.
The timecode in VDJ 5 is open source SDK for for plugin development to support most types of timecode... :)
will fix the links - sorry about that ...... willl post here as soon as download links are fixed
geposted Wed 22 Aug 07 @ 7:00 pm
https://virtualdj.com/products/timecode/VDJTimeCode_pro.mp3
Rightclick, Save As
Rightclick, Save As
geposted Wed 22 Aug 07 @ 7:08 pm
Thanx andrew ;)
that link works until the links on the webpage is fixed too ;)
geposted Wed 22 Aug 07 @ 7:10 pm
Webpage fixed too:
(thanks Damien)
geposted Wed 22 Aug 07 @ 8:13 pm
No go .. Im curious if anyone has been able to get this to work with the BCD 2000 ?
geposted Wed 22 Aug 07 @ 9:07 pm
Have you got it all set up properly? I.e. you've connected your cd decks to the BCD2000's line inputs and have selected cd mode within VirtualDJ's timecode config? Could you post a screenshot of this screen please?
geposted Wed 22 Aug 07 @ 9:19 pm
@ Andrew87
Its only one Deck ... and I have connected it into both channels A & B on the BCD 2000 testing. I have also selected both cd & vinyls .. it works in both... but gives 0% quality.
I can post screen shots .. but im not sure what ones you will want to see .. and what configuration... I have been working with this for 3 days now trying to get it to work .. It not like I just plugged it in an started crying.... I have tried everything I could think of.
A rehash of some of my issues.
----- I have 1 CDJ mk2 800, BCD 2000, vdj 4.3, dell latitude 610
OP wrote :
OP ----- > it seems after i pass 12 mins or so, the timecode stops working..0% timecode quality, but it works.. then after that time passes, when i move the vinyl the vinyl on screen moves still but the song keeps going... by itself.. i cant control it i have to press config and choose the asio4all instead of the BCD 2000asio picture under asio driver and then song skips a bit as it chooses that one then i can control the music again. <-----OP
beach wrote :
Also ... when it gets to the end of one time code(I have 6 on one cd) . . it pauses/skips the music while it reads / starts up the second track .. .and it does this on relative , absolute or smart mode.
-------- Ok .... ive got TWO versions of VDJ running on two separate machines. ----
4.3 .. .same problems ...... nothing has changed ... even with the new cd's.
5.0 ... I still get 0% timecode quality ... but it plays longer then 12 min .. it still skips the music when going from one timecode track to another.
geposted Wed 22 Aug 07 @ 10:14 pm
