Hi ,
I'm new here. I want learning to mix with virtualdj.
What are different ways of mixing ( and how to do )?
Thank you very much
Yannick ( Yakke )
Thank you very much
Yannick ( Yakke )
geposted Fri 10 Aug 07 @ 7:31 am
hi there
check out the user guide for starters be sure to read the sticky threads particularly the one on Club mixing and beatmatching :)
every one here is always happy to help:) so if you ever have a problem just let us know
Welcome to the virtual dj family
geposted Fri 10 Aug 07 @ 6:49 pm
Hello
I am new using This.
I have so many problems.
I am using the computer destop window XP connecting to another mixer.
I hook the computer to the mixer by using one channel on the mixer and one sound card from the the computer.
My Problem is this: I can't pre-listing to the second music in the headphone before mixe it to the first.
Can someone help me ?
Do I need to use two channels on the mixer ?
Help me
Thanks
Help me
Thanks
geposted Sun 12 Aug 07 @ 4:46 pm
hi there why not try the newer virtual dj www.virtualdj.com
instead
it has many more features and updates
instead
geposted Sun 12 Aug 07 @ 5:07 pm
Hello
I am new using virtualdj.
Help me
Thanks
Help me
Thanks
geposted Mon 13 Aug 07 @ 3:39 am
good day,
i have alot of problems using virtual dj
1. how can i mix two songs from my laptop that has only one channel output sound but connected to thee mixer without it realising the song unmixed to the audience?
2. my virtualdj showed me a skin error and refuse to open.
3. thhe sound configure area has 2 points, 1 point, 4 points. the 2 points mixes for earphone only, but not when playin in a party.
4. can't i update my virtual dj 2.0 to a newer version instead of a trial version?
i would like this questions to be responded too soonest.
geposted Mon 13 Aug 07 @ 10:25 am
1. That u have to use a at least 4.1 card, for prelisten too.. (2 in 2 out).
2. U have to uninstalled n try reinstalled. betta yet try the official demo.
3. Not really sure what u are askin:)
4. If u bought pro, go n register urself in ur profile to take the latest version n benefits..
But if u use the "FUNKY" version, u have to buy to have the update.
geposted Mon 13 Aug 07 @ 10:35 am
then uninsatll the old version and sound drivers then re install the New bought copy
Cheers
Kaoz
geposted Tue 14 Aug 07 @ 9:26 am
i just need held on my dj mix tape if you any body can help me
geposted Tue 11 Sep 07 @ 5:47 am
Hi...
To pre listen a music with a one way out PC sound card you must buy the
Hercules 5.1 Channel Audio Adaptar.
Try www.pixmania.com for example, +- 27€
geposted Thu 13 Sep 07 @ 3:03 pm
What is beatmatching? I'm not 100% sure. Could someone shed some light please?
geposted Wed 19 Sep 07 @ 8:59 pm
look at this
http://www.virtualdj.com/forums/5408/Mix_lessons/BPM___MIXING_GUIDE_(for_hip_hop__rnb_and_many_other_genres).html
http://www.virtualdj.com/forums/6288/Mix_lessons/DJ_MIXING___basic_-_advanced_-_pro.html
http://www.virtualdj.com/forums/9931/Mix_lessons/Club_Mixing.html
geposted Wed 19 Sep 07 @ 9:41 pm
hola alguien habla espanol
la verdad no se como se hace el mix aveces ago mix pero la verdad no se si estan buenos o no pero donde puedo ver como lo hacen o como
puedo empezar hacer mix las canciones gracias de antemano
betoo
betoo
geposted Thu 20 Sep 07 @ 5:52 am
hello i have got the hercules mk1 and i am unabel to prelisten to one song in my headphones as i have only got a one channel output coming from my laptop. if i purchase the hercules 5.1 sound card that you suggested would i be able to prelisten to one track in my headphones while another trackk is being played through my speakers.
Let me know asap thanks guys!
geposted Thu 11 Oct 07 @ 1:27 pm
hi! i really want to know how i can organise my playlist when mixing. like mixing a hip hop song with a slow.
geposted Thu 15 Nov 07 @ 12:21 pm
well u really just dont wanna mix all just rap songs you want to mix generes up
geposted Sat 24 Nov 07 @ 5:05 am
