I am not sure how, but when I go to virtualdj.com everything is in spanish... how can I change that?
The second question is....I had to re-install Virtual DJ becuase of a hard drive failure. When I re-installed it the bar that moves across showing the beats and sound volume (Ones Red the other Green)when the music plays is really small. It use to be really big. Any way I can change that?
Thanks everyone.
Thanks everyone.
geposted Fri 10 Aug 07 @ 5:37 pm
If you go to the homepage you can click the flag which represents with your language. Or click this flag:
If you're using the default skin there is a slider to zoom between views. Or use the 1, 2 and 3 buttons to quickly zoom between presets.
geposted Fri 10 Aug 07 @ 5:44 pm
