I will own the VCI-100 because I found it better than Hercules or Numark´s for my needs, but I have read somewhere that there is no support yet for this unit. It is that true?
If it is true, In the future in another version can VDJ fulled controlled by the VCI-100 ?
If so, when will be relased?
Thanks!
Thanks!
geposted Fri 10 Aug 07 @ 11:34 pm
I heard it had not really natively supported yet but read some of the thread here n do more search on this:)
http://www.virtualdj.com/forums/31/Hardware_Technical_Support.html?search=vci-100
http://www.virtualdj.com/forums/71121/Hardware_Technical_Support/Who_have_vestax_vci_100.html?highlight=vci-100
http://www.virtualdj.com/forums/68989/Hardware_Technical_Support/Mapping_jog_wheels_for_Vestax_VCI-100.html?highlight=vci-100
The team are aware of this n maybe the future release it will be fully supported n the time of release only the team knows the answer:)
Btw u could just purchased the software, hence can get the free updates as well ltr when the new updates are release.. no need to wait till the next version:)
geposted Sat 11 Aug 07 @ 6:06 am
Whoops, I forgot the search button. Sorry & thanks!
Anyway, any users reviews or comments?
thanks!
thanks!
geposted Mon 13 Aug 07 @ 5:49 am
