Which one is faster or and better?
Thanks
Thanks
geposted Sat 11 Aug 07 @ 1:38 am
Firewire
geposted Sat 11 Aug 07 @ 1:59 am
yes.firewire
geposted Sat 11 Aug 07 @ 3:49 am
i thing usb is bettre becaus ethe speed id 480mbs than firewire 400 mbs.what you have to say for this?
geposted Sat 11 Aug 07 @ 10:03 am
speeds are "up to 480mbs" do they actually transfer that fast?
is it possible to make a external usb hdd in to a firewire hdd?
geposted Sat 11 Aug 07 @ 10:13 am
well that depends on the quality of the cable and the device in question
most sources point to firewire if you have a port its ment to be faster in expermiments
however you may wish to consider for most compatablity ie if you ever want to use it on another computer , every pc has atleast one usb port.
its not possible to change that unless you remove the internal harddrive and place it into a firewire external drive caddy , which would void all hope of a warrently
geposted Sat 11 Aug 07 @ 12:43 pm
Firewire is generally faster and can sustain better read speeds. It also has dedicated bandwidth, usb has to share everything. Firewire uses a peer to peer architecture but usb uses the dated master-slave (which I don't think we're allowed to call in computing anymore because it's not politically correct).
But as sky mentions, usb has the best compatibility - nearly any machine you use, whether it's at a library or a friends will have usb. Not all will have firewire.
geposted Sat 11 Aug 07 @ 4:45 pm
Just for interests sake, if you have a computer with an eSATA port on it, then this will obviously outperform both USB and FireWire.
This is because the hardware doesn't have to convert and re-convert the hard drive signals to USB / FW and back again. eSATA provides the same bandwidth as an internal SATA drive.
geposted Sat 11 Aug 07 @ 5:56 pm
or a cheap arse clubmangers computer never again will i make that mistake lol owch
geposted Sat 11 Aug 07 @ 6:08 pm
My vote goes to eSATA, tried it and it is faster than anything else. Off course, this makes sense only on faster HDD's (250GB and above where 16MB cache starts).
geposted Sat 11 Aug 07 @ 6:36 pm
