Hello!
I’m seeking a program to make m3u playlists. I once had a program named Footbar (or something like that) but I erased it by accident and now I can’t find it anywhere. Do any of you know this program (or someone better) then please let me know where to get it!
Regards
Mads
Regards
Mads
geposted Mon 13 Aug 07 @ 11:09 pm
Foobar2000, although Windows Media Player and iTunes will both make m3u playlists.
geposted Mon 13 Aug 07 @ 11:10 pm
aslo vdj makes playlists drag the tracks you want
and on the side list click the ... symbol and choose save to make a playlist
geposted Mon 13 Aug 07 @ 11:19 pm
Foobar without the t.. Thank you! :-)
Didn’t know WMP cut save in m3u.
I find the playlist editor in VDJ a little complicated to use. that's why i like foobar I think it's more simpel.
geposted Mon 13 Aug 07 @ 11:35 pm
No problem. Foobar is a great little player, low memory usage and 0% cpu - can't really get better than that as a player. I prefer WinAmps media library though, I find it prettier.
To save playlists in WMP as m3u, when you're saving a playlist just change the save as type box to m3u.
geposted Mon 13 Aug 07 @ 11:42 pm
Kool.. I will try that! :-)
geposted Mon 13 Aug 07 @ 11:50 pm
Try Media Monkey. You can make playlists and then batch export them to open in VDJ.
geposted Tue 28 Aug 07 @ 4:33 am
i'm with sky i think ... why not just do it natively ......that means either a) just do it all in vdj or 2) ? do it with a native ......
geposted Tue 28 Aug 07 @ 6:56 am
