I want to buy the BCD the 3000 and Virtual DJ to work with Video. virtual 3000 BCD X DJFuncionam well with video? It will be that it can stop the computer or the BCD?
Tank's
Tank's
geposted Tue 14 Aug 07 @ 4:20 pm
BCD is a controller and it will work with VDJ, but I suggest better ones like Numark Total Control or DMC2.
geposted Tue 14 Aug 07 @ 5:45 pm
I think maybe some people have got the bcd3000 working- but I'm not sure.
Total control from numark would be a better option, or the hurcules if you're on a budget
geposted Tue 14 Aug 07 @ 6:03 pm
friends, I do not want to mixar the video in Hercules MK2. I can mixar the video in the Virtual DJ. Now, if I to make one scratch in Hercules MK2, the screen of virtual dj the video also I will make scratch? This is my doubt. Only work with videos, I do not only present audio, always I use videos. Videos functions well with the MK2?
geposted Tue 14 Aug 07 @ 6:58 pm
MK2 is a midi controller (as Numark also) and you can map it to do whatever you need. Video is just another aspect of mixing, but for good scratching I suggest something with bigger jogs like XP10 or Numark iCDX.
geposted Wed 15 Aug 07 @ 2:39 pm
