Is it possible to pre-listen decks A and B in the headphones in mix mode?
I just want to pre-listen both descks a dont send out the music out by the loudspeakers, or just send out just the music played on one deck.
Sorry for my english.
Thank you.
Thank you.
geposted Thu 16 Aug 07 @ 10:38 pm
which version do you use?
geposted Thu 16 Aug 07 @ 11:00 pm
i have tried many versions but now i use 3. 4
Can you help to solve my problem?
Thanks in advance.
Thanks in advance.
geposted Thu 16 Aug 07 @ 11:17 pm
You could try using "split" on the headphone switch. This is the only way I can think of at the moment to hear what's playing in both decks in the headphones while one is playing live. You hear one deck in your left ear and the other in your right.
Hope this helps
BTW, posts such as this one really should be placed in the hardware technical support forum. You stand a much better chance of receiving more useful answers there. This forum is more of a general discussion area ;)
Hope this helps
geposted Fri 17 Aug 07 @ 5:55 am
