When I joined here I made a mistake and gave my serial # for my Cue LE and not my Full Version, does anyone know how I can switch that.
I want to get some of the effects but can't because i'm using the Cue LE.
Thanks For Your Help.
Rich
Rich
geposted Fri 17 Aug 07 @ 5:14 am
Should be able to go back to the -- http://www.virtualdj.com/fusers/modifuser.html
And just enter the CUE Pro serial in the box. And then you will get the CUE box logo by your name on the left
geposted Fri 17 Aug 07 @ 5:17 am
Thanks for the help .... means alot!
geposted Fri 17 Aug 07 @ 5:19 am
