I can not get VDJ to recognize zip files. using Vista I can't change the Codecs..
Help
Help
geposted Fri 17 Aug 07 @ 6:34 pm
Another entry for the PC Software FAQ perhaps:
http://www.virtualdj.com/forums/72799/General_Discussion/zip_problems.html
geposted Fri 17 Aug 07 @ 7:00 pm
VDJ 5 fixes the ZIP file issue
The "problem" with Vista is that it sees all zip files as folder by design.
geposted Fri 17 Aug 07 @ 7:24 pm
