Forum: Old versions
Topic: Automix
The first few songs will mix smooth, but then the remainder of the songs, the slider will fly over and mix suddenly. What causes this and how can I correct it? I notice the cue points are different each time on the autoplay function. Sometimes it is at the beginning of the song, the other time it will be one third into the song and it will alway mix too fast. What determines the cue points and how can I get it too mix smooth everytime? It is set on smooth.
geposted Wed 13 Oct 04 @ 8:32 pm
ok, force fade solved the problem. Is there anyway to automaticaly set the beat match?
