i need some quick help i want to connect my cd players to the virtural dj it is possible to use the cd with with virtural what is the set up.....
geposted Sun 19 Aug 07 @ 8:37 am
you need virtual dj pro
and a soundcard with two stereo inputs such as maya 44 usb or u46dj mk2
or the mk2 dj console or numark virtual vinyl
geposted Sun 19 Aug 07 @ 12:22 pm
i have it the mk2 and i using the pro do i for soundcard i have the audio soundcard
geposted Sun 19 Aug 07 @ 8:54 pm
Do register in ur profiles:) As u say u do have the MK2 n Pro version,,
Get the V5 -its outs.. :D
N like skyfxl said u need 2 in (stereo) 2 out(stereo) cards (As mentioned - some of the few)
What cards u using??
geposted Sun 19 Aug 07 @ 8:57 pm
i have the audio genie and the mk
geposted Sun 19 Aug 07 @ 9:09 pm
i have the old mk when came it first those work to
geposted Sun 19 Aug 07 @ 9:13 pm
Get the maya .. From what i c that audio genie card has only 1 stereo in n 1 stereo out.. U cant use that for timecoded.:(
Is this ur cards?
http://www.adjaudio.com/product.asp?ProductIDNumber=1306&cat=Software
U need 2 stereo in or 2 stereo out or in other werds 4 in 4 out (mono).. :).. N from what i heard.. not from personal experience that mk1 card is not good.. , hence i think its best u invest cards such as maya etc..
N pls register ur serial okay:D n grab the latest version:)
Is this ur cards?
geposted Sun 19 Aug 07 @ 9:18 pm
how is the connection they go to soundcard first then to mixer
geposted Sun 19 Aug 07 @ 9:33 pm
yes,,
tt/cd >soundcard>mixer>amp
geposted Mon 20 Aug 07 @ 8:55 am
