is it possible to have both versions installed?
if so that's what I will do so I can test v5 when its slow at the club. :)
thanks.
ps....I looked for a topic on this but didn't see one unless I misssed it which is possible.
thanks.
geposted Mon 20 Aug 07 @ 3:25 am
yap ;)
In your current VirualDJ 4 folder, copy the virtualdj.exe file, and paste into same directory. Rename the copied file if you like, to say VirtualDJ 4.3.exe
Then install VirtualDJ5.
To run VirtualDJ 4 double-click the VirtualDJ 4.3.exe, or if you like, make a shortcut to desktop.
VDJ4 and VDJ5 uses separate databases, and run fine together
geposted Mon 20 Aug 07 @ 3:30 am
sweet. thanks. I got my work cut out for me now with tagging of files so I can use genre. this is gonna be fun.
geposted Mon 20 Aug 07 @ 4:43 am
