Topic: Understanding XP10
Wondering, if you hook up XP10, will VDJ still work the same minus you having to use the mouse? Example, will the automix feature still work the same as if the XP10 was not hooked up? If I leave the booth for 3 songs, and have been working with the XP10, and decide to load some songs in the playlist area of VDJ, just want to make sure this is still as simple. Deciding on whether to purchase XP10, and want to make sure it doesn't complicate things.
geposted Thu 14 Oct 04 @ 6:36 pm
ivarPRO InfinityMember since 2004
everything works the way you want it to work !!!
and it is not complicated at all, when i first got them it took me one afternoon to get use to them
geposted Thu 14 Oct 04 @ 7:08 pm
