Many greetings from the Czech republic.
Please, could You help me?
I understand, when I want pre-listen second song in my headphones, I have tu use external soundcard (soundcard in my laptop is not suitable).
I don´t want to spend much money, so I have chosen TRUST-SC-5500P-EXTERNAL-SURROUND-SOUNDCARD
(http://www.amazon.co.uk/TRUST-SC-5500P-EXTERNAL-SURROUND-SOUND/dp/tech-data/B0002Z2QQY/ref=de_a_smtd/026-0749951-6784408).
Could You aswer me, if will this soundacard work or not?
Thank You!
Thank You!
geposted Mon 20 Aug 07 @ 7:54 pm
Hey, please!? Is here somebody, who can help me?
geposted Tue 21 Aug 07 @ 7:54 am
that will be fine for headphone use
geposted Tue 21 Aug 07 @ 9:34 am
I have little fear about usb. There is written, that this soundcard has USB 1.1. It means, that usb cable will have one 1.1 USB end and one 2.0 USB end, that I will plug in my laptop? Thanks.
geposted Tue 21 Aug 07 @ 9:42 am
No, you have one cable and you can use it on 1.1 standard as this is enough throughput for sound card. You can use 3 channel external mixer with this, 2 for decks and third for samples. You should consider also Sound Blaster LIVE 5.1 USB.
geposted Tue 21 Aug 07 @ 10:54 am
Sorry, I explained my question bad. I wanted ask, if this connecting cable between external soundcard and my laptop has two different ends? One 1.1 USB (for soundcard) and one 2.0 USB (for connection with my laptop)? Because in laptop I have only slots for 2.0 USB. I hope this soundcard will work good. I ordered it one hour ago. :)
geposted Tue 21 Aug 07 @ 11:17 am
