Hi,
The Automix button has been removed from the top centre on vdj version 5, do you have to enable it somewhere or is there another way to mix from one deck to the other?
Also does anyone know of any skin 1024 x 768 which dispays the key changer for Karaoke on the main screen?
geposted Tue 21 Aug 07 @ 5:09 pm
the automix has been improved
http://www.virtualdj.com/forums/74929/General_Discussion/VirtualDJ_5_-_New_Features_user_guide.html
please consult the manual
geposted Tue 21 Aug 07 @ 5:10 pm
Matter of opinion Sky, the actual mix quality might have been improved. However i did predict that people wouldn't be over happy with the single deck mixing. Seems my prophecy was correct!
geposted Tue 21 Aug 07 @ 5:42 pm
My Timecode Power skin has a key display (display only, i use keyboard shortcuts to change)
Works well with 5.0.
http://www.virtualdj.com/addons/skin.html?id=2214
geposted Tue 21 Aug 07 @ 7:37 pm
Hi,
Can you automix from deck to deck with this skin or have you got to manually slide the slider?
Also is there anyway of viewing videos with this skin?
What are the keyboard shortcuts to put the key up and down and reset?
Many thanks
Many thanks
geposted Tue 21 Aug 07 @ 8:04 pm
billy24 wrote :
Hi,
Many thanks
Many thanks
Automix is now in one deck only, not depended from the skin.
If you mean to auto move the crossfader its the auto_crossfade shortcut.
For key i use "Key_offset" +100, and -100, also there is a reset parameter.
NOT designed for video, sorry.
geposted Tue 21 Aug 07 @ 8:27 pm
Might be opinion - but it is reality. Get over the old and get into the NEW. Hate to be so blunt but it is what it is -- an automix just like Windows Media Player, WinAmp and any other. IF you have to see the track before it auto plays then I feel sorry for you. And if you are standing there watching the automix play then why not mix it yourself. I don't know how many posts I have read with the 'bad automix' in 4.x where people complained that they couldn't walk away because it was 'broke', not that it is fixed and even better - we complain that we need to see it on both decks ? Just don't get it.
geposted Wed 22 Aug 07 @ 4:53 am
Agreed it works flawless and video transitions smoother than ever!! Plus now I can have a new song loaded and ready to go when I am done with the automix.
geposted Wed 22 Aug 07 @ 5:05 am
