when playing a play list, the music doesnt seem to beet match. iv active Sync etc. how can u do it so automix uses both decks like normal.
geposted Tue 21 Aug 07 @ 7:37 pm
Using both decks is not possible in v5. The reason that it works this way is so that you have an open deck available to "plug" a track into when you want to.
geposted Tue 21 Aug 07 @ 7:42 pm
how come the beatmatching seems out tho how can i make it beet match thanks?
geposted Tue 21 Aug 07 @ 7:45 pm
if you are using the automix , it is all automatic on one deck other wise
to sync on two decks , enable Always match on bpm
or hit the sync button on the deck you wish to match
geposted Tue 21 Aug 07 @ 7:47 pm
In terms of automixing, I've found that if your CBGs are off, beatmixing will not work properly. Try setting up a short list of tunes with prominent beats for which you have confirmed the CBG. If that works as expected, I think you've found the trouble and will want to manually edit BPM on the tracks you want to automix while you're setting up your playlists for the gig.
geposted Tue 21 Aug 07 @ 7:52 pm
if u goto radio.facelush.com u can here the beets not matching up
geposted Tue 21 Aug 07 @ 7:58 pm
