When selecting multiple files with holding shift and selecting first and last files in browser. This works if you select the top one then the last one you wish to select, but if you select the last one, then the first one you want to select, it only selects the first one, as if you let go of the shift button.
Trivial, but a bug none the less, usually it doesn't matter what order you select the files while holding shift.
geposted Wed 22 Aug 07 @ 9:23 am
