Hey everyone,
I have been having a blast doing videos at some gigs and all is working perfect.I see that the new ver5 is out and I am being a bit cautious about upgrading .You know..if it aint broke dont fix it thinking.Old school I guess..!
anyway..I want to know when I downlod the update and install it..will it creat a seperate file of its own or just overwrite the existing ver ?
I ask this just in case it develops a problem and I need it for this weekend.
Appreciate any input fellow dj'rs!!
geposted Thu 23 Aug 07 @ 1:39 am
Hi, the trick is to go to "my computer" -> harddrive-> program files -> virtual dj and rename virtualdj.exe to something like virtualdj4.exe (if you have a shortcut to vdj on your desktop you might have to replace it after re-naming the virtualdj.exe)
Then you can install the new version as normal.
geposted Thu 23 Aug 07 @ 2:20 am
Thanks andytaylor125,
I also realized that my upgrade isnt available yet.. I have Virtual Vinal. True?
geposted Thu 23 Aug 07 @ 5:35 pm
True true :)
geposted Thu 23 Aug 07 @ 5:58 pm
