I'm having a problem with the DMC2 with the Cue Pro.
The DMC2 came with the Cue LE and I bought the Cue Pro also because I was told it had more features.
But when I hook the DMC2 up to my Lap Top using the Cue Pro, The DNC2 flashes (PC Link Not Found
If someone could give me some pointers or help that would be great.
The DMC2 works great with the Cue LE, but I want to use it with the Cue Pro.
Rich
Music Search:
www.NuMusicHitz.com
geposted Thu 23 Aug 07 @ 3:07 am
In Cue, click config, then the "remote control" tab. Then where it says "Numark DMC2" tick the "enable" box. Does that fix it?
Also, the DMC will say "PC Link Not Found" until you launch Cue, then all goes well.
geposted Thu 23 Aug 07 @ 11:53 am
please dont double post :( you already have 3 topics with answers on it
geposted Thu 23 Aug 07 @ 1:23 pm
